Internet connectivity issue with firewall
May 11th, 2009
We recently had a T1 put in by qwest with them providing static ip address's and a qwest basic router. We are currently running a ASA 5505 behind the router, and a Linksys wireless router behind the ASA 5505.
The issue at hand is I went through the wizard to setup our firewall with the static IP address. Pretty basic figuring we just wanted to test it.
From the Firewall ASDM software I can ping websites, but from my PC I am not able to get out to the web.
The error I get is as follows
portmap translation creation failed for udp src inside:192.168.1.2/49286 dst outside:205.xyz.2.65/53
The 205 address is the DNS servers qwest has provided to us. So I am a little confussed why its going there and not our outside IP.
Here is my config, file.
interface Vlan1
nameif inside
security-level 50
interface Vlan2
nameif outside
security-level 0
ip address 65.xyz.153.146 255.255.255.248
interface Vlan3
shutdown
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 205.xyz.3.65
name-server 205.xyz.2.65
domain-name default.domain.invalid
access-list VPN standard permit 192.168.1.0 255.255.255.0
access-list VPN standard permit 10.10.10.0 255.255.255.0
access-list outside_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 65.xyz.153.145 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.10 inside
dhcpd dns 205.xyz.3.65 205.xyz.2.65 interface inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Jon Marshall Mon, 05/11/2009 - 12:16
You are not translating your internal addresses to routable addresses on the Internet. You have this in your config -
you need a corresponding global statement. Add this to your config -
global (outside) 1 interface
Jon
John Blakley Mon, 05/11/2009 - 12:16
Two things:
1.) You may want to check with the provider to make sure they bridged the router that's in front of your ASA. If they didn't, you won't be able to get out :-)
2.) You're missing "global (outside) 1 interface"
What the last line does is match up with your nat statement. The nat statement tells the ASA that anyone who arrives on the inside interface gets natted, but it doesn't have anything to nat to because you're missing the global statement.
HTH,
John
jlight80911 Mon, 05/11/2009 - 12:25
I completly overlooked that. Thank you for the quick reply everyone, I will go test it right now!
Thanks again!
