Accessing MMS server from outside through ASA
May 11th, 2009
There is one Windows MMS server sitting inside the network.
I have done port based static natting in the ASA for that server with port 554(rtsp) as we dont have more public IPs.
for this natted IP I have allowed IP any any. Still when I am trying to connect to the server everything else is accessible except the video files. I am not able to play the video files. Whereas I able to play from inside.
sachidananda panda Mon, 05/11/2009 - 13:28
rtsp inspection was there in default list. But even after removing that also it is not working. Only thing I suspect is on the port based natting.
SHANNON WYATT Tue, 05/19/2009 - 09:30
Try this. Try connecting to the server internally via the Media Servers fully qualified domain name. If this works put in a host entry on a PC outside the firewall with the fully qualified domain name in the c:\windows\system32\drivers\etc\host file.
I had this problem after I followed the document on excluding RTSP for the server. After we added DNS for the server on the outside everything worked. I guess that it encaps the server name in the RTSP, not the translated IP address.
