05-11-2009 07:12 PM - edited 07-03-2021 05:34 PM
Hello, the 861-W specification say it can support 10 SSIDs, but only 2 VLANs. Can someone please explain how this is possible. I tried to assign the same VLAN to two different SSIDs, but received an error message saying this was not possible.
Here's my test config
Current configuration : 3264 bytes
! Last configuration change at 20:59:00 EDT Mon May 11 2009
! NVRAM config last updated at 21:01:52 EDT Mon May 11 2009
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 <hash>
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
dot11 mbssid
dot11 ssid <1>
vlan 1
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 <hash>
dot11 ssid <3>
vlan 3
authentication open
mbssid guest-mode
dot11 ssid <2>
vlan 2
authentication open
mbssid guest-mode
username Thomas privilege 15 secret 5 <hash>
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 2 mode ciphers aes-ccm
ssid <1>
ssid <3>
ssid <2>
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
station-role root access-point
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface GigabitEthernet0.3
no ip route-cache
bridge-group 3
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 3 protocol ieee
line con 0
no activation-character
line vty 0 4
exec-timeout 120 0
login local
sntp server 64.90.182.55
end
05-12-2009 08:56 AM
Anybody?
05-13-2009 06:08 AM
I'm pretty sure you don't need the bridge protocol ieee used at the end of your config. Also, can you post your router config? This looks properly configured, but there may be an issue on your router.
Make sure your Gigabit interface to the AP is configured for trunking.
05-13-2009 06:45 AM
The official word from Cisco Tech Support is as follows:
"After looking further into this issue, I’ve been able to determine that the documentation is unclear. You can have a maximum of 2 vlans, and 10 SSIDs. If you do not map the SSIDs to VLANs, the ISR can hold a total of 10 SSIDs, with only one broadcasted. If you map them to VLANs, however, you will be unable to have more than 2 SSIDs enabled on your router. So the functionality to create more than 2 working WLANs on your AP is not there on the 861W. "
I think that you're right about the "bridge protocol ieee" command. However, I think that it's the defualt bridge protocol. If I try to execute "no bridge protocol ieee", the sub-interface is deleted.
In any case, here's the router config I had been using:
version 12.4
no service pad
hostname pa-router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
no ip source-route
no ip dhcp conflict logging
ip dhcp pool 0
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 209.198.87.24
ip dhcp pool 1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
domain-name voicesforvtkids.org
ip dhcp pool 2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip cef
ip domain name publicassets.org
ip name-server 209.198.87.24
archive
log config
hidekeys
ip ssh version 2
interface FastEthernet0
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
switchport access vlan 2
no cdp enable
interface FastEthernet4
ip address 207.136.xxx.xxx 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
interface Vlan1
ip address 192.168.0.1 255.255.255.0 secondary
ip nat inside
interface Vlan2
ip nat inside
interface Vlan3
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 207.136.xxx.xxx permanent
no ip http server
ip nat inside source list NAT interface FastEthernet4 overload
ip access-list standard NAT
permit 192.168.0.0 0.0.0.255
permit 192.168.1.0 0.0.0.255
permit 192.168.2.0 0.0.0.255
no cdp run
05-13-2009 10:26 AM
That's crazy - I've never heard that before. Only 2 SSIDs? Have you tried just running 2 SSIDs? Does that work?
I don't see anything wrong with your config. What exactly happens with what you have configured? Do you see any of the SSIDs you have configured?
05-13-2009 10:53 AM
Yeah, and that fact that it has only two Vlans is not terribly well documented either.
I do see the three SSIDs; they are being broadcast and I can associate to all three. However, only two of them will pass data. Clients on the third one cannot connect to the DHCP server. The other two work fine.
05-14-2009 04:42 AM
Well, I guess the issue can't be fixed then, if Cisco is saying that 2 SSIDs is your max.
So weird... I've still never heard of that before.
