Analyze ACE capture buffer
May 11th, 2009
Good morning.
I am able to take an ACE capture buffer and get it into a file on a PC. However, this format isn't very readable. Can someone please point me to a tool which can convert the file into something legible, or else explain to me how I can convert it manually?
TIA
- Godfrey
Gilles Dufour Tue, 05/12/2009 - 02:32
  • Cisco Employee,
With the latest software version, when you do 'copy capture disk0:' the capture is converted into a pcap file readable with any sniffer tool like wireshark.
Just rename the file into something.cap and if you have wireshark, it should be able to decode it.
Gilles.
resbanknet Tue, 05/12/2009 - 03:42
Thanks, I never realised that there was a difference between this method and the
sh capture BUFFER detail > tftp: way.
