Help with WLC Internal DHCP and Clients jumping between SSIDs
hello friends,
we have 2 4402 controllers with SSID1 (Enterprise) and SSID2 (Guest). SSID2 is configured for web auth without any secret key. I have 2 issues at this time.
1: users connected to SSID1 (enterprise) sometimes automatically just to Guest SSID2 and stay there until manually moved back.
2: For Guest SSID2 controllers are doing DHCP (scope split between controllers). I sometimes see an issue where users lose their IP address for about 60secs and so cannot access anything. it usually works again after about 60sec but then their VPN drop which is annoying.
Has anyone else seen this? is there any setting on WLCs that i can try to fix this?
thanks
Anand
George Stefanick Tue, 05/12/2009 - 05:00
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Anand,
1: Not sure the client you are using but you may want to make sure you have a SSID1 profile set up on all the clients. If the client moves from SSID1 to SSID2 its likely they are out of coverage or have an issue connecting to SSID1 and resort to SSID2. Check to see if the area where is this happening has an issue connecting to SSID1 as well.
2: How do you have your DHCP set up? Is the guest controllers in the same mobility group? Is each controller doing DHCP? Are the DHCP scopes in the same range?
If you have 2 controllers giving out DHCP it sounds to me that perhaps when the client roams from one controller to another its re-DHCPing, no?
Robert.N.Barrett_2 Tue, 05/12/2009 - 09:06
  • Bronze, 100 points or more
For #1 - Perhaps you should create the Guest wireless profile on all machines, and disable it.
Depending on the wireless client, "disabled" could mean a setting of "connect manually". If you are using the Wireless Zero Config client on Windows machines, you can push this out via GPO.
You should also ensure that the private profile has the highest priority of the wireless network profiles (this is another setting that you can control via GPO for machines using Wireless Zero Config).
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
