ios_config from tcl script called as service from dial-peer
May 12th, 2009
Can anyone comment whether the tcl command "ios_config" is supported when a script is run as a service, executed from a dial-peer, or how to make it work?
After sorting out an issue with script signing (thanks jclarke!) I am now facing this as my next issue.
When the script executes I get errors like "invalid command "ios_config"", and the configuration commands that should be run obviously arent.
Thanks.
Tom
Paolo Bevilacqua Tue, 05/12/2009 - 08:53
I think TCL/IVR and tclsh do not share extensions. That is, certain things you can do only from one and not the other.
It is tricky to do configuration from a TCL/IVR script. I tought of few ideas one is to post config changes in a flash file executed by a tclsh "daemon".
tom.storey Tue, 05/12/2009 - 15:45
Hi Paolo,
Do you know if it is possible to use the exec command?
Perhaps you could execute a script via tclsh and pass it a couple of parameters?
Tom
