How to Configure UC520-16U-4FXO-K9 as a Voice gateway ?
May 12th, 2009
I have Cisco UC520-16U-4FXO-K9, and I want to use this in my Lab as my Voice Gateway and it does have the ISDN 2 BRI's, Can I configure this as a Voice-Gateway for call testing purpose?
When I try to add this to the Call Manager 6 Gateway option, I don't see the name of UC520 in the list ? Any help or documentation will be appreciated.
mhurley131 Tue, 05/12/2009 - 03:42
You have to add it as a h323 gateway and configure the correct dial-peers on the UC520.
wahidayat007 Tue, 05/12/2009 - 03:49
Thanks for your reply! I am going to add this in Call Manager, and see how it works!
I will reply to you shortly and will give you points!
Nicholas Matthews Tue, 05/12/2009 - 15:06
  • Red, 2250 points or more
FYI - the UC520 is not supported with CUCM. This is because CUCM is designed as a large enterprise solution and the UC520 is only meant for single or small multi-site enterprise.
You may be able to get it to work, but it's not a TAC supported configuration.
-nick
paolo bevilacqua Tue, 05/12/2009 - 20:28
  • Hall of Fame,
    Founding Member
Nick, as the OP says, it's for a lab :)
Nicholas Matthews Wed, 05/13/2009 - 06:22
Yes - but labs very quickly turn into TAC cases, plus the anyone else that reads this. The information certainly isn't hurting anyone, hence FYI.
-nick
wahidayat007 Thu, 05/14/2009 - 04:10
well, apart from the above discussion, I am trying to connect UC-520 with another 3550 switch with a trunk port, but it is not communicating and not sending any vlan's information across the trunk link ?
Any idea ?
paolo bevilacqua Thu, 05/14/2009 - 07:51
  • Hall of Fame,
    Founding Member
The router will not send any vlan information. Just make sure the VLAN ID you configured on both side matches.
wahidayat007 Fri, 05/15/2009 - 00:49
Yes Vlan ID matches, but apart from CDP , I can't ping any SVI from both sides ? Is there any security implemented on UC-520 ?
paolo bevilacqua Fri, 05/15/2009 - 05:29
  • Hall of Fame,
    Founding Member
Not unless explicitly configured.
Uou likely have some configuration mismatch.
