ERROR: mapped-address conflict
May 12th, 2009
When I try to add a second PAT statement I get the following ERROR:
ERROR: mapped-address conflict with existing static
inside:A.B.C.D to outside:DEVICE 1_Public netmask
The existing config is:
static (inside,outside) tcp DEVICE 1_Public https DEVICE 1_Private 8443 netmask
static (inside,outside) tcp DEVICE 1_Public ssh DEVICE 1_Private ssh netmask
static (inside,outside) DEVICE 1_Public DEVICE 1_Private netmask
I'm trying to add
static (inside,outside) tcp DEVICE 1_Public 44324 DEVICE 1_Private 44324 netmask
Why can I not add this new line?
John Blakley Tue, 05/12/2009 - 05:47
I'm guessing that it's because you have a one-to-one mapping already:
Take the above line out, and you'll be able to add your line. Or, you can remove all of the lines and leave the above line in, and then control access through acls.
