Syslog viewer
May 12th, 2009
Dear All,
In LMS any software is for viewing the syslog files.
Joe Clarke Tue, 05/12/2009 - 09:33
Viewing the raw syslog.log file? No. You can use a text reader to do that.
However, you can view the messages which RME has processed, and added to its database by running the various syslog reports under RME > Reports > Report Generator.
subashmbi Tue, 05/12/2009 - 22:09
Thanks Clarke,
If the log size is more than 2gb, the text reader will not support, any other tool can support this large files to open.
