CCM Cluster "REPLICATION NETWORK" interpretation in error log
Hi all,
Here an extract of "utils dbreplication status"
Selected node <NODE NAME> does not appear in this replication network; aborting status check operation for that node
Network connectivity is OK.
Any possible interpretation ?
thanks inadvance.
best regards,
irisrios Mon, 05/18/2009 - 14:09
  • Silver, 250 points or more
try to reset replication for that one node using the cli 'utils dbreplication reset '
If this doesn't works then use cluster reset cli 'utils dbreplication clusterreset'
