Create subinterface
May 12th, 2009
Hello
I have a catalyst 3750 switch with version c3750-advipservicesk9-mz.122-46.SE.bin installed. Now I would like to configure vrf-lite. I have made all the configuration for vrf and ospf. For the connection to the next router I configured a port as no switchport. Now I tried to configure a subinterface. I always got an error like
PM5(config)#inter gig 1/0/3.10
% Invalid input detected at '^' marker.
Is there anything wrong in my configuration or do I have a wrong image file on the switch?
thank you for your help
regards,
Alex
davy.timmermans Tue, 05/12/2009 - 04:22
I'm not sure but I think it's not possible.
If it's not supported you've to work with SVI's instead and using a trunk
guruprasadr Tue, 05/12/2009 - 06:34
HI, [Pls RATE if HELPS]
By default, the Catalyst 3750 or 3550 is a switch performing L2 functions and has L3 unicast routing disabled. You can enable this function by issuing the 'ip routing' global command.
If you want to convert any port to a L3 port, issue the 'no switchport' command. Do not configure Ethernet sub-interfaces on a switch. Configure it as a trunk, and terminate the L3 IP interface on a Switched Virtual Interface (SVI).
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
