Unity Call handler - call limitations?
Answered Question
May 12th, 2009
I have a question with regards to Unity's Call Handler....
Is there a maximum to the number of calls at any one time that Unity can handle when accepting a call into a call Handler or is it a case that it depends on the number of ports configured/available to take a call, or does it handle a call on a per-call basis?
Correct Answer by Rob Huffman about 7 years 10 months ago
Hi Paul,
Like you nicely noted, the only limitation here would be based on the number of available Ports (set to answer calls) that are not "in use" for other functions.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Tue, 05/12/2009 - 04:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Paul,
Hope this helps!
Rob
paul_savage Tue, 05/12/2009 - 05:08
Rob,
Thanks....most helpful, it did help.....you've confirmed my thinking :-) sometimes you need a sanity check....could't find much documentation to support my assumption....
regards
Paul
Rob Huffman Tue, 05/12/2009 - 05:46
  • Hall of Fame,
    Founding Member
Hey Paul,
I usually need a sanity check about once every 14 minutes ;-)
Cheers!
Rob
