detection of a raid disk failure
May 12th, 2009
what the way to detect a failure on a physical drive belonging to an array ?
Ginger Dillon Tue, 05/12/2009 - 07:30
Hi -
The failed drive will have a red X on it. If you have an HP server running HP System Tools, you can check the HP Array Configuration Utility. In the configuration view, you will see the failed logical drive as well. Also on the System management main page, you will see System status, which will also show a failed drive.
ppicory Thu, 05/14/2009 - 08:07
Thanks for your answer.
Now, is there a way to get this information automatically when it happens : by mail or SNMP OID change status ?
I don't want to connect every day to CUCM to check the HD status.
best regards
Knightvoice_2 Thu, 08/26/2010 - 05:08
I am looking for a soltion for this also.Can
it be done through RTMT?
