Encrypted ip-load-sharing per-packet
Answered Question
May 12th, 2009
Hi community,
right now we have 2 1841Router with IOS-AdvSec 12.4(19) in use.
The 2 Routers are connected via Serial 0/0/0 and Serial 0/0/1 and do ip load-sharing per-packet. In the future we would like to encrypt this connection. Which configuration steps would be necessary to implement encryption while maintaining ip load-sharing over these 2 serial interfaces?
Would it be possible to use the same crypto Map on both interfaces?
This ist the configuration of the serial interface(s):
Interface Serial0/0/0
ip address x.x.x.x 255.255.255.252
no fair-queue
Interface Serial0/0/1
no fair-queue
This is our standard crypto map which we would like to use:
crypto isakmp policy 100
encr aes
authentication pre-share
group x
crypto isakmp key
xxx
address 1.xx.xx.xx
crypto isakmp identity hostname
crypto ipsec transform-set AES-256 esp-aes 256 esp-sha-hmac
crypto map ROUTERVR 100 ipsec-isakmp
set peer 1.xx.xx.xx
set transform-set AES-256
match address 122
Thanks in advance,
Alexander
Correct Answer by Laurent Aubert about 8 years 2 weeks ago
Hi Alexander,
You need two different crypto-map as even if the peer address is different, the proxy ACL is the same so you can't have two entries in the same crypto-map:
encr aes
group x
crypto isakmp key xxx address 0.0.0.0
crypto map ROUTERVR-S0/0/0 100 ipsec-isakmp
set peer 1.xx.xx.xx
match address 122
crypto map ROUTERVR-S0/0/1 100 ipsec-isakmp
set peer 2.xx.xx.xx
match address 122
crypto-map ROUTERVR-S0/0/0
crypto-map ROUTERVR-S0/0/1
Keep your static routes to implement load-balancing. the crypto will intercept the packets and encrypt them.
Laurent.
Overall Rating: 5 (2 ratings)
Correct Answer
Laurent Aubert Tue, 05/12/2009 - 05:35
  • Cisco Employee,
Hi Alexander,
encr aes
group x
set peer 1.xx.xx.xx
match address 122
set peer 2.xx.xx.xx
match address 122
Laurent.
mtorzewski Tue, 05/12/2009 - 05:48
Alexander,
I am doing something similar tomorrow and will let you know how it goes. I will be adding IPSEC over two T1 private lines between two sites. I am load sharing per destination versus per packet. I use the same crypto map for both interfaces. I tested this in the lab and it works fine.
mtorzewski Wed, 05/13/2009 - 10:37
I added IPSEC to two serial interfaces successfully today using the same crypto map. The two interfaces are doing load balancing per flow.
paolo bevilacqua Tue, 05/12/2009 - 06:15
  • Hall of Fame,
    Founding Member
Have you measured performances when using 1 vs 2 link in per-packer load sharing ?
Probably you're wasting a lot of bandwidth due to out of sequence packets that are be discarded by the host.
For true utilization of both links simultaneously, use only per-flow or MLPPP.
