AP-1131AG radiation pattern
May 12th, 2009
Hi All
How should I mount an AP-1131AG for the best coverage area? vertical(wall) , Horizontal(ceiling).
Thank you.
yuttana_su Sun, 05/31/2009 - 00:37
Thank you. Jeff
From the E-Plane radiation ,Can I mount on the wall ?. or If I mount on the middle of room (Vertical ) what is the effect?
Thanks you.
scottmac Sun, 05/31/2009 - 05:19
You can hang it on the wall. The effect will be to change the polarity of the pattern by 90 degrees (to horizontal), which may or may not be detrimental, depending on the client.
Usually you'd be looking at ~3dB or so drop for a polarization mismatch.
Good Luck
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
