DND and presensce on SPA932
May 12th, 2009
I use SPA962 with SPA932 and SPA942. I use the Server Type: RFC4235 on SPA932. Sip account is used on SPA942. IT works ok, SPA932 is correctly signalling the status, but there is a problem when i use DND on the SPA942 phone.
When I set DND at SPA942 on YES, SPA932 don't change the status of this line to BUSY. The SPA942 do not send any SIP information when i set on/off DND.
How can I set the config to watch DND mode on the phone ?
Alberto Montilla Tue, 05/12/2009 - 09:33
  • Cisco Employee,
Dear Sir;
Will escalate this to a higher hierarchy on the support. As soon as I get a response I'll let you know.
Alberto
Alberto Montilla Thu, 05/14/2009 - 03:55
  • Cisco Employee,
Dear Sir;
Have a reply.
DND setting does not affect the user status in the SPA932, it is by design. Currently there are no plans to implement this feature enhancement for SPA932.
Alberto
