Stupid question - If the lightweights lose connection to the controller
May 12th, 2009
  • Bronze, 100 points or more
Will they still broadcast a SSID and function. My gut tells me no.
(specifically we are concerned about WAN sites loosing connectivity back to the data center and if the local wireless at the remote site will work)
sachinraja Tue, 05/12/2009 - 07:29
  • Red, 2250 points or more
Hello
lwaps tunnel traffic across the controller, and hence in a local mode, without the WLC, the LWAP wouldnt work.. thats probably why we need dual WLC's with failover configured.. mobility groups would help us achieve this.. Hence for local setup (such as LAN), you cannot have the LWAP broadcast SSID's if the WLC is down..
For remote sites, over the WAN, you can look at H-REAP... "H-REAPs can switch client data traffic locally and perform client authentication locally when the connection to the controller is lost. When connected to the controller, H-REAPs can also tunnel traffic back to the controller. (from CCO).."
Have a look at this doc:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807cc3b8.shtml
Hope this helps.. rate replies if found useful..
Raj
George Stefanick Tue, 05/12/2009 - 07:44
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
nope. Once an AP loses connection it will go "offline" and not broadcast the SSID in local mode.
If you did H-REAP for local offices you can do local-switching mode which will allow for client to still gain access to the wireless should the AP lose controller connection.
Anonymous (not verified) Tue, 05/12/2009 - 09:30
Cool, thanks.
yeah I forgot about HREAP. Ive been spending too much time in the motorola world...
Leo Laohoo Tue, 05/12/2009 - 15:06
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
They're right. If H-REAP is configured, when the WLC goes off-line, the AP will continue to function and process as if the WLC is still present ... on the proviso that the AP'S do not get rebooted.
