Mobile Connect on BRI is not supported but why?
May 12th, 2009
actually I'm trying to configure Mobile Connect on BRI Ports, I know from this document, that it does not work:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/mobilapp.html#wp1043943
Having a look on the MGCP controlled BRI port:
May 12 14:39:57.392: ISDN BR0/0/1 Q931: TX -> SETUP pd = 8 callref = 0x18
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x0081, '01'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '017662032618'
May 12 14:39:57.520: ISDN BR0/0/1 Q931: RX <- CALL_PROC pd = 8 callref = 0x98
Channel ID i = 0x8A
Exclusive, B2
ver.vgw2#
May 12 14:40:03.936: ISDN BR0/0/1 Q931: RX <- ALERTING pd = 8 callref = 0x98
ver.vgw2#
May 12 14:40:06.488: ISDN BR0/0/1 Q931: RX <- CONNECT pd = 8 callref = 0x98
Date/Time i = 0x09050C1026
Date (yr-mm-dd) = 09-05-12
Time (hr:mnt:sec) = 16:38:174
ver.vgw2#
May 12 14:40:15.656: ISDN BR0/0/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x98
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
I can clearly see the connect and disconnect messages. Does anyone know why? Has someone tried to get it working with H323?
This question is more out of interest. Any answer or idea is very much appreciated.
Cheers
Christian
c.hennrich Wed, 05/13/2009 - 01:34
I configured H323 and now I'm able to use Mobile Connect on BRI Ports.
Cheers
