Frequent disconnections on PIX
May 12th, 2009
I have a PIX 506E and have problems with frequent disconnections on LAN side.
E1 interface is connected to the switch and a server and workstation are connected to the switch. After 10-15 minutes I am not able to browse the internet both from server and workstation. Testing and results as below
Switch in place - E1 to switch - server
- Stops browsing after 10-15 minutes
- Can still ping the pix unit from the server. Doing a continuous ping and no time outs
- But cannot telnet to pix from server
- Can see the pix E1 interface is up, line protocol up and connected with full duplex with no errors
- Cannot ping the server from PIX
- Windows firewall disabled on server
- Server NIC connected to Auto and also tested with 100full
- Can ping external IP from PIX console which tells me there is no problem with Internet
Switch in place - E1 to switch - workstation
- Same as above
Connected E1 directly to server/workstation
- Same as above
On all the above tests, initially I rebooted the PIX unit and the connection comes back up. At one point I did a shut and unshut on E1 interface and the connection between the PIX and the server was up.
Seems to me it is PIX E1 interface hardware issue. Any suggestions please?
Thank you
rsherman@thesms... Wed, 05/13/2009 - 12:49
How many devices behind the pix traverse the outside interface (go out to the internet)?
What is the inside host licensing on the pix?
techtips03 Mon, 07/27/2009 - 05:38
Turns out the problem is with the fan and the PIX is gettin so hot.
