Config for cisco 877 using PPOE
May 12th, 2009
hi,
Does anyone have a config for a Cisco 877 DSL router that is using PPOE?
I normally use PPOA and jsut can't can't this PPOE DSL line working.
For the ATM I am using this:
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
dsl operating-mode auto
Dor the Dialer:
interface Dialer1
ip address negotiated
ip access-group inbound in
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname eircom
ppp chap password 0 broadband1
ppp pap sent-username eircom password 0 broadband1
crypto map Crypto_Map
When I do a sh dsl int atm 0 it says showtime and the speed of the line and the CD light is constant.
I turned on debug ppp neg and debug ppp auth and see nothing!
Any ideas?
Collin Clark Tue, 05/12/2009 - 09:36
  • Purple, 4500 points or more
Working Config:
<font size="2"></p><p>interface FastEthernet4</p><p> description OUTSIDE$ETH-WAN$</p><p> no ip address</p><p> no ip redirects</p><p> no ip unreachables</p><p> no ip proxy-arp</p><p> ip route-cache flow</p><p> duplex auto</p><p> speed auto</p><p> pppoe enable group global</p><p> pppoe-client dial-pool-number 1</p><p> no cdp enable</p><p></p><p>interface Dialer0</p><p> description FW_OUTSIDE</p><p> ip address A.B.C.D 255.255.255.248</p><p> ip access-group outside_access in</p><p> ip mtu 1452</p><p> ip nbar protocol-discovery</p><p> ip nat outside</p><p> ip inspect FIREWALL out</p><p> ip virtual-reassembly</p><p> encapsulation ppp</p><p> ip route-cache flow</p><p> dialer pool 1</p><p> dialer-group 1</p><p> ntp disable</p><p> no cdp enable</p><p> ppp authentication pap callin</p><p> ppp pap sent-username <a href="mailto:[email protected]">[email protected]</a> password 0 SeCrEt</p><p>!</p><p>dialer-list 1 protocol ip permit</p><p></font>
I also have PPPoA if you need it.
jamesgonzo Tue, 05/12/2009 - 11:03
Should it matter I use and ATM 0 on my Cisco 877 as it looks like your use an ethernet port on an 878 or similar.
Also I've not been asked to add and IP to the dialer like you have below, although I do have a static IP:
Collin Clark Wed, 05/13/2009 - 05:14
jamesgonzo Wed, 05/13/2009 - 05:20
Thanks, I have never had to add the static Ip to the dialer one port before I leave it as "ip address negotiated" is it import to include this on the dialer0 interface if I'm using PPOE?
Collin Clark Wed, 05/13/2009 - 05:22
If you're using DHCP use 'ip address negotiated' instead.
jamesgonzo Wed, 05/13/2009 - 05:23
Is this if our ISP is issing a dynmaic IP address?
Collin Clark Wed, 05/13/2009 - 05:38
If you have a static IP use-
If you have a DHCP address use-
The rest of the config is the same.
jamesgonzo Wed, 05/13/2009 - 05:55
Some of the example configs use:
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
and under the dialer
dialer remote-name redback
what are these?
