Flash problem
May 12th, 2009
Recently I bought a FLASH memory; I tied replacing it with the FLASH mem I had.
The problem is, its not working...
rommon 15 > tftpdnld -r
IP_ADDRESS: 192.168.2.111
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 192.168.2.1
TFTP_SERVER: 192.168.2.222
TFTP_FILE: c2600-i-mz123-26.bin
Receiving c2600-i-mz123-26.bin from 192.168.2.222 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
File reception completed.
program load complete, entry point: 0x80008000, size: 0x765238
Self decompressing the image : ############################################################################################################################# [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0000A2 0X00103980 C2600 Dual Fast Ethernet
0000CC 0X00179614 High Density Voice Port Module
0X00098670 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00526604
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 6Mb.
Not enough memory in the system to run this image
Required pmem/iomem: 26934890/629145
*** System received a Software forced crash ***
signal= 0x17, code= 0x200, context= 0x80005f7c
PC = 0xffffffff, Vector = 0x200, SP = 0xffffffff
rommon 16 >
If I dont use -r option, I get the result pretty fast,
rommon 8 > tftpdnld
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: y
get_man_dev: Unknown device - probably NOT formatted.
unknown flash device - mandev code = 0xffff
cannot read flash info
TFTP: Error, insufficient flash installed to load image.
TFTP: Operation terminated.
rommon 9 >
rommon 16 > dir flash:
getdevnum warning: device "flash" has size of zero
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
dir: cannot open device "flash:"
rommon 17 >
rommon 17 > meminfo
Main memory size: 24 MB.
Available main memory starts at 0x10000, size 24512KB
IO (packet) memory size: 25 percent of main memory.
NVRAM size: 32KB
rommon 18 >
Please try helpin me..!
Sylvester.
framedrelay Tue, 05/12/2009 - 08:58
http://cgi.ebay.com/NEW-BOOTROM-CISCO-2620-2621-MEM2620-32FSBOOT-BOOT-2600_W0QQitemZ380052757417QQcmdZViewItemQQptZCOMP_EN_Networking_Components?hash=item587ce8dba9&_trksid=p3286.m20.l1116
I think i will need to buy bootrom, else it doesnt recognise 32MB flash? Sounds rubblish,
Cisco 2600 Series Boot Rom MEM2620-32FSBOOT
Enable your Cisco 2620 and 2621 to recongize 32MB of Flash memory capacity
Part Number: MEM2620-32FSBOOT
Bootrom version 12.1(3r)T2
Currently im running -
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 24576 Kbytes of main memory
Leo Laohoo Tue, 05/12/2009 - 14:43
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Sylvester,
This is one of the biggest pain to a 2600 router. You can't upgrade the bootstrap easily and require additional purchase and downtime. This was identified and starting from the 2691 onwards (3725/3745) you can now upgrade the bootstrap using software.
