Extension Mobility
cris_jimenez
Level 2
Level 2
Hello Folks,
I have CCM 7.0.2
I want to configure EM, however when I go to services on the phone and select EM I get this error
"[208]-EMService Conn.error"
I confirm that the EM service is activated and running
I have my device default profile
I have the end user device profile and associated to the End user.
EM is enabled on the phone
please let me know
Jaime Valencia
Hey Cris
might be hitting this bug
CSCsx45240
Unable to contact EM Service
Symptom:
Install Publisher
Install subscriber
Enable EMService in Subscriber
Use the EMApp in publisher for configuring the EM phone service
Try to do a EM login from a phone. The login fails with EM Service Conn Error.
Conditions:
Enabling EM Service in Sub and using the EMApp in pub for EM login
Workaround:
Restart Cisco Extension Mobility Application network service
Further Problem Description:
Enabling EM Service in Sub causes the EMApp's change notification handler thread in Pub to throw an exception in the background. As a result, the EMApp stops maintaining the list of active EM Services in the cluster. Hence when a phone attempts login, it fails with EM Service Conn Error
Related Bug Information
CSCsx61556
Try the WA or get in touch with TAC to get the ES that fixes this
java
if this helps, please rate
java
Jaime Valencia
Hey Cris
CSCsx45240
Symptom:
Install Publisher
Install subscriber
Conditions:
Workaround:
CSCsx61556
java
java
