05-12-2009 08:19 AM
I have some models of 3750 cisco Series WS-C3750-24TS,cisco WS-C3750G-24T and cisco WS-C3750G-24TS-1U. In the last model when i put the command show env all i see this:
sw-crr-core#sho env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 33 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 55 Degree Celsius
Red Threshold : 65 Degree Celsius
POWER is OK
RPS is NOT PRESENT
In the other model i only get this:
sw-cmn-core#sho env all
FAN is OK
TEMPERATURE is OK
POWER is OK
RPS is NOT PRESENT
Someone can explain to me this?
I can monitorized Temperature using Nagios/MRTG the WS-C3750G-24TS-1U only. The others model i cant do that
What can i do in this case?
Ty and Best Regards
05-12-2009 09:48 AM
Not all devices have the necessary sensor hardware to report real temperature values. In such cases, all you can do is check to see if the temperature is in a valid range. This can still be managed from SNMP, though. You need to poll the chassisTempAlarm value from the CISCO-STACK-MIB. A value of 1 is good (it means there is no alarm). A value of 2 means the temperature is out of range, and a value of 3 means the temperature is critical.
05-12-2009 11:14 AM
Thank you clarke. Let me try monitorized that swithc using Nagios and the OID that you tell me. Something that i ask you is the Value of 2 of this OID is like a Warning value? and if you know in ºC what means 1,2 or 3 for example 1 <35ºC, 2 means since 36ºC until 50ºC and 3 means >50ºC
Thanks in advanced
CA
05-12-2009 11:37 AM
For you particular models, it looks as though only the chassis alarm on value is supported (i.e. you will not see a critical). This is determined indirectly by looking at the fan sensor, and occurs around 70 C.
