How do block a range of ip's via PDM on PIX 501
Answered Question
May 12th, 2009
I need to block a range of ip's, 123.8.0.0 to 123.15.255.255. How do I do that?
Correct Answer by John Blakley about 7 years 10 months ago
That's correct. And I made a mistake because the PIX doesn't use inverted masks, so it would be:
123.8.0.0 255.248.0.0
John
Overall Rating: 5 (1 ratings)
John Blakley Tue, 05/12/2009 - 10:46
  • Purple, 4500 points or more
You can create an acl like:
access-list BLOCKED deny ip 123.8.0.0 0.7.255.255 any
This will cover you from 123.8.0.1 - 123.15.255.254.
HTH,
John
jwbutler123 Tue, 05/12/2009 - 12:23
If i'm using the PDM I assume 123.8.0.0 would be the ip and 0.7.255.255 would be the mask. Is my assumption correct?
Correct Answer
John Blakley Tue, 05/12/2009 - 12:25
John
