05-12-2009 09:08 AM - edited 03-21-2019 01:05 AM
I want to upgrade the flash to 2gig. I formated the new flash FAT, then I copied the flash to a file on my hard drive then onto the new flash. I installed the flash & the UC520 booted up. I am able to see the config, the new backgroud we made comes up on the IP phones. But the ip phones cycle between registering to configure Ip. They never come up. I looked at the files that were on the old flash & compaired them to the new flash. Everything appears to be the same. Has anyone ran into this issue before?
Thanks in adbance
Steve
05-12-2009 11:37 AM
Have you enabled the debugs in CLI?? Try "debug tftp events", and show me the output when you reset the phone...
Eivind
05-12-2009 08:04 PM
Also, please notice that non-Cisco parts are not supported by our TAC.
Marcos
07-16-2013 10:07 PM
So what are the Cisco SKUs for 256/512/1024/2048mb CF cards supported in the UC5** series?
Do they come pre-formatted?
07-16-2013 10:40 PM
Don't bother. Any good brand works fine.
07-16-2013 10:42 PM
Ahh; I was just about to close my eyes when I rememberd: The Cisco UC520 is just a bastardized 2800 router.
So in theory, the MEM2800-512CF or MEM2800-256CF would be a good place to start to avoid awkwardness with TAC and lost sleep.
Night ~BAS
07-16-2013 10:47 PM
Again: don't bother. There is no way to tell which brand CF is installed without looking at it physically.
If you have a support contract, Cisco TAC will send a CF replacement on demand.
If you don't, TAC will not support you at all.
