Routing Issue (MP-BGP-MPLS) ?
May 12th, 2009
  • Gold, 750 points or more
I have 3 routers, PE1 -- P --- PE2
MPLS LDP is setup between all 3 routers. MP-BGP is setup between PE/PE2. The problem is i cannot ping any interfaces in RNS/Smart-Cluster between PE1/PE2!!!
Any Ideas?
PE 1
ip vrf RNS
rd 200:200
route-target export 200:200
route-target import 200:200
ip vrf Smart-Cluster
rd 100:100
route-target export 100:100
route-target import 100:100
no ip domain-lookup
vtp domain none
vtp mode transparent
mls ip slb purge global
no mls acl tcam share-global
mls netflow interface
no mls flow ip
no mls flow ipv6
mls cef error action freeze
mpls ldp holdtime 15
mpls ldp advertise-labels for LDPInterface
mpls label protocol ldp
vlan 60
name Smart-Cluters
vlan 61
name RNS
interface Loopback0
description MPLS LDP Interface
ip address 172.18.254.3 255.255.255.0
interface Loopback1
description OSPF Router ID
ip address 172.17.254.3 255.255.255.0
interface Loopback102
ip vrf forwarding RNS
ip address 192.168.102.1 255.255.255.0
interface Vlan60
ip vrf forwarding Smart-Cluster
ip address 192.168.60.10 255.255.255.0
interface Vlan61
ip address 192.168.61.10 255.255.255.0
router ospf 1
router-id 172.17.254.3
log-adjacency-changes
passive-interface default
no passive-interface GigabitEthernet6/2
network 172.17.254.3 0.0.0.0 area 0
network 172.18.254.3 0.0.0.0 area 0
network 192.168.2.2 0.0.0.0 area 0
network 192.168.254.0 0.0.0.255 area 0
router ospf 4 vrf Smart-Cluster
redistribute bgp 1 subnets
network 192.168.60.0 0.0.0.255 area 4
router ospf 3 vrf RNS
network 192.168.61.0 0.0.0.255 area 3
network 192.168.102.1 0.0.0.0 area 3
router bgp 1
no synchronization
bgp log-neighbor-changes
neighbor 172.17.254.2 remote-as 1
neighbor 172.17.254.2 update-source Loopback1
no auto-summary
address-family vpnv4
neighbor 172.17.254.2 activate
neighbor 172.17.254.2 send-community both
exit-address-family
address-family ipv4 vrf Smart-Cluster
redistribute ospf 4 vrf Smart-Cluster match internal
no synchronization
exit-address-family
address-family ipv4 vrf RNS
no synchronization
exit-address-family
ip classless
no ip http server
no ip http secure-server
ip access-list standard LDPInterface
permit 172.18.254.0 0.0.0.255 log
mpls ldp router-id Loopback0
francisco_1 Tue, 05/12/2009 - 09:33
PE2
PE 2
ip vrf RNS
rd 200:200
rd 100:100
no ip domain-lookup
vtp domain SW-ESB2TSRD43
no mls flow ip
no mls flow ipv6
mls cef error action reset
Vlan 60
name Smart-Clusters
vlan 61
name OSPF-Nei-Adj
interface Loopback0
ip address 172.18.254.2 255.255.255.0
interface Loopback1
ip address 172.17.254.2 255.255.255.0
interface Loopback100
ip address 192.168.88.1 255.255.255.0
interface GigabitEthernet4/1
ip address 192.168.1.2 255.255.255.0
ip ospf priority 0
mpls ip
Interface Vlan60
ip address 192.168.60.2 255.255.255.0
interface Vlan61
ip address 192.168.61.2 255.255.255.0
interface Vlan999
description OSPF Adj
ip address 192.168.99.1 255.255.255.0
router ospf 1
router-id 172.17.254.2
no passive-interface GigabitEthernet4/1
network 172.17.254.2 0.0.0.0 area 0
network 172.18.254.2 0.0.0.0 area 0
network 192.168.1.2 0.0.0.0 area 0
network 192.168.88.1 0.0.0.0 area 3
router bgp 1
no synchronization
neighbor 172.17.254.3 remote-as 1
neighbor 172.17.254.3 update-source Loopback1
no auto-summary
neighbor 172.17.254.3 activate
neighbor 172.17.254.3 send-community both
exit-address-family
no synchronization
exit-address-family
redistribute ospf 3 vrf RNS
no synchronization
exit-address-family
ip classless
no ip http server
Giuseppe Larosa Tue, 05/12/2009 - 12:09
  • Hall of Fame,
    Founding Member
Hello Francisco,
first of all, each af ipv4 vrf vrf-name under router bgp should have at least redistribute connected otherwise the local prefixes are not advertised over the VPNv4 af to the remote PE.
From experience I would put red connected in every af ipv4 vrf vrf-name.
verify with
sh ip bgp vpnv4 all
that each PE receives the routes of the other one.
Second step:
troubleshooting MPLS forwarding plane
sh mpls forwarding remote-PE-BGP-loopback
you will see that you are using
172.17.254.x addresses for BGP but you are not allowing labels to be created and advertised for them.
this is the root cause of your connectivity issue
I would suggest the following:
use one set of loopbacks for:
OSPF, LDP and BGP
Hope to help
Giuseppe
Harold Ritter Tue, 05/12/2009 - 12:28
  • Cisco Employee,
Francisco,
Make sure that you use a 32 bit mask on the loopback interface IP addresses. This is always recommended when setting up MPLS VPN.
In this specific example the loopback interfaces of PE1 and PE2 use overlapping IP addresses (i.e. 172.18.254.3/24 on lo0 PE1 overlaps with 172.18.254.2/24 on lo0 PE2 and 172.17.254.3/24 on PE1 lo1 overlaps with 172.17.254.2/24 on PE2 lo1).
Also as Giuseppe recommended, it would definitely be a good idea to use the same loopback address for both LDP and OSPF.
