IPS Load monitoring using SNMP
May 12th, 2009
Since CPU is always 100% now in v6.x/v7.x - is anyway to monitor the system load (reported in IDM/IME) using SNMP?
What counter can be a good indicator for system upgrade that can be monitored using SNMP?
Overall Rating: 5 (2 ratings)
rhermes Mon, 05/18/2009 - 15:19
The sensors have dual CPUs (or are dual core). The first CPU frequently reports 100%, but the second CPU shows a variable CPU range, when both hit 100% you're in trouble.
Monitoring both via SNMP should be easily achieved. The sensors follow the standard host MIB.
potterjosh Wed, 06/17/2009 - 06:50
Currently you can not query IPS senor load via SNMP, there is a feature request out for it.
If you want to monitor load right now you can write a script that logs into the sensor and preforms a "show statistics virtual-sensor | i Load"
This is a snapshot, and I believe the GUI provides an average.
potterjosh Wed, 06/17/2009 - 10:18
I was incorrect in stating you can watch that statistic for the load level. The command I gave you just displays "value is a measurement of how much of the CPU/Processor is being used by traffic inspection." -Cisco
