upgrading hardware for Unity 7
May 12th, 2009
We have an IBM 345 server that we are upgrading the processor to make the configuration this.
CPU: Xeon3.40Ghz
RAM: 4 GB
HD: 2 x 73 GB
DVD available.
Has anyone successfully tried this?
Are there any cautions I should address?
Your comments are greatly appreciatied.
Thank you,
Terry
Ginger Dillon Wed, 05/13/2009 - 08:11
  • Blue, 1500 points or more
Hi Terry -
If this is going to be a production server, I recommend you consider this hardware supported doc link for Unity and review the port and voice capacity specifications as this can require adding more disks, memory etc. - http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd802132ef.html
Down in the doc it discusses requirements for Unity. Now this configuration may be OK for a test server ...
Ginger
