Tracing 911 call
Answered Question
May 12th, 2009
Can somebody advise me on the best way to trace 911 calls coming from inside our facility - we are running CUCM 6.1(2) so no SQL DB to look at. This has happened multiple times but we cannot seem to find what extension is dialing it.
Thanks in advance!!
Correct Answer by Jaime Valencia about 7 years 11 months ago
CAR is a good option, you still can run qrys to informix DB via the CLI
ie
run sql select * from car:tbl_billing_data where originalcalledpartynumber='911'
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 05/12/2009 - 13:05
  • Cisco Employee,
  • Hall of Fame,
    2011
ie
java
pcaltagirone22 Wed, 05/13/2009 - 07:56
Thanks very much! Great info.
Is there a clean way to export that data into some type of spreadsheet?
tgledbetter Fri, 05/29/2009 - 05:05
Hi javalenc; is there a good Cisco doc explaining CLI queries for CDR lookups on 6.1?
lupemacias Tue, 05/12/2009 - 15:43
I've also recently moved to 6.1(2). I was running 4.1(3) and had it sending my CDRs to a SQL server making it easy for me to search for calls. The upgrade broke my setup and I was faced with either purchasing ER or IPcelerate for 911 call notification.
After playing with CCM for a while, I was able to configure it to ftp the CDR records to another server. I then wrote a simple app that would get the uploaded CDR files and upload them to my SQL server. While the program is processing the CDR files, it keeps a lookout for 911 calls. If the app finds a call that is no older than 5 minutes it sends an email to a list of predefined uses.
