05-12-2009 04:07 PM - edited 03-18-2019 11:02 PM
My CUE notification to cell phone is working in the sense that a few seconds after a VM is received the system dutifully calls my cell phone and lets me know. However, I would think that during the notification message I could hit some key to login and listen to this new message, no? Is there such a key? * and # don't seem to work. It seems silly that I have to hang up and call back to listen to the message. Any thoughts?
Solved! Go to Solution.
05-13-2009 04:31 AM
Hi Diego,
You are most correct my friend!
voicemail notification allow-login
To allow subscribers to log into their voice mail during outgoing notification calls, use the voicemail notification allow-login command in the Cisco Unity Express configuration mode. To prevent subscribers from accessing their voice mail during notification calls, use the no or default form of this command.
no voicemail notification allow-login
default voicemail notification allow-login
Syntax Description
This command has no arguments or keywords.
Defaults
Voice-mail login is disabled.
Usage Guidelines
Use the voicemail notification allow-login command after the message notification feature is enabled system wide.
This capability is available only for phone devices.
If the capability is enabled, the system provides the subscriber with an option to log into voice mail to retrieve the message.
If the capability is disabled, the system plays a notification prompt three times before disconnecting the notification call.
Examples
The following example enables voice-mail login during notification calls.
se-10-0-0-0# config t
se-10-0-0-0(config)# voicemail notification enable
se-10-0-0-0(config)# voicemail notification allow-login
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/Command/v_cmds.html#wp1016582
Hope this helps!
Rob
05-13-2009 04:31 AM
Hi Diego,
Syntax Description
Defaults
Usage Guidelines
Examples
Hope this helps!
Rob
05-13-2009 04:39 AM
Dang! That was right there in the GUI and I missed it. Talk about not seeing the forest for the trees!
Thank you Rob, you are a scholar and a gentleman.
Diego
05-13-2009 04:53 AM
Hey Diego,
You are most welcome buddy! I loved your "forest for the trees analogy" as this happens to me daily :)
Cheers!
Rob
