Oracle 10G and UCCX 5.0 Database Connection return 0 rows on query
May 12th, 2009
Currently I have an issue with UCCX 5.0 and Oracle 10G, we need to access a table on an Oracle10G DB, form IP IVR, so I installed the driver, created the ODBC connection and declared the ODBC, user and password on the Database subsystem (name on UCCX match the ODBC name) and restarted the engine.
Im trying to do simple select statement (SELECT * FROM TABLE) and I'm getting a 0 count once I test it.
emontero Mon, 04/19/2010 - 10:37
I see it has been a while since you posted this question, but I am having exactly the same problem with an Oracle integration and I was wondering if you were able to fix this and how.
Your reply will be greatly appreciated.
Eduardo
