iftikharsyed_2 Tue, 05/12/2009 - 20:57
If you are using select resource, try changing timeout value also from appadmin - > system -> system parameters change Agent State after Ring No Answer to ready.
hth,
regards,
iftikhar
csshenoy80 Tue, 05/12/2009 - 21:13
Will config change need to be done on the CUCM as well?
iftikharsyed_2 Tue, 05/12/2009 - 23:15
Yes if you have changed default values or u have voice mail integrated.
raynorris Wed, 05/13/2009 - 01:13
You will need to set the timeout setting on your select resource step to 60 seconds.
Then ensure that all the agent phones have a ring no answer time set to a number higher than this otherwise you may / will experience peculiar issues.
Ray
Ray
