Assign two VLAN ID to a single Port of a Switch
Answered Question
May 12th, 2009
I have 3 VLANs in my network and i would like to expose two VLANs(VLAN 2 and 3) to outside and the third VLAN(VLAN 4) is for internal use only.
At the outside interface point, i plan to place a switch.
I need to configure the switch Port(to which i am connecting my network) to accept VLAN2 and VLAN3 and reject VLAN4 packets.
Does any Cisco switches provide such configuration support?
As per my understanding, one Port of a switch can be assigned with only one VLAN ID.
Please correct me if i am wrong.
thanks
renjith
Correct Answer by Leo Laohoo about 7 years 8 months ago
Hi Renjith,
Glad to be of help. Please rate when applicable. Thanks.
Overall Rating: 4 (1 ratings)
Leo Laohoo Tue, 05/12/2009 - 21:37
Hi Renjith,
Typically, you can only assign ONE VLAN per port with the exception of Voice VLAN.
However, if you want to push 2 VLAN's per port, configure the port to be trunk and allow the VLANs you want.
renjith.rv Tue, 05/12/2009 - 21:46
Hi leolaohoo,
Thank you very much for the prompt reply.
Let me know,Can i specifically configure the trunk Port to accept the VLANs which i need(say VLAN 2 and 3) and discard all other VLAN packets(say VLAN4 and 5)?
Leo Laohoo Tue, 05/12/2009 - 21:49
Hi Renjith,
Sure you can. Go to the interface and configure "switchport trunk allowed vlan 2,3".
Only data from VLANs 2 & 3 will be accepted and discard the rest.
Hope this helps.
renjith.rv Tue, 05/12/2009 - 22:04
Hi leolaohoo,
Yes. This information is really valuable for me. thank you very much
Let me clarify one more thing, Can i configure any Port of the Switch as a trunk Port? (Say, '24 Port Switch' and i need to configure Port 8 and 16 a trunk ports)
renjith.rv Tue, 05/12/2009 - 23:42
Hi leolaohoo,
lamav Wed, 05/13/2009 - 08:14
Hi:
You can configure any port on a switch as a trunk port. Typically, the trunk ports are reserved for those that have fiber interfaces, but not necessarily.
Victor
renjith.rv Wed, 05/13/2009 - 20:35
Hi leolaohoo,
I have gone through the link you provided.
Yes. This helps.
thank you.
Correct Answer
Leo Laohoo Wed, 05/13/2009 - 21:03
Hi Renjith,
