Spanning-tree issue
May 12th, 2009
Hi Guys
I have got a weird issue. A switch I have nominated does not appear to be forwarding for a particular vlan over a trunk (please see below).
Port Mode
Encapsulation Status Native vlan
Gi0/46 on 802.1q trunking 1
Gi0/48 on 802.1q trunking 1
Po1 on 802.1q trunking 1
Po2 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/46 1,31
Gi0/48 1-4094
Po1 1-4094
Po2 1-4094
Port Vlans allowed and active in management domain
Gi0/46 1,31
Gi0/48 1,30-31,71,73
Po1 1,30-31,71,73
Po2 1,30-31,71,73
Port Vlans in spanning tree forwarding state and not pruned
Gi0/46 1,31
<strong>Po1 1</strong> (issue is here not forwarding VLAN31)
Po2 1,30-31,71,73
The switch is connected to another switch using a 3Gbps etherchannel... but for some reason does not want to forward this vlan. It is causing another issue as a different interface on both switches then goes off to two other switches and certain devices attached to these cannot communicate (all on VLAN31). I think this is causing the issue but am not sure how to fix it.
I have checked the trunk links and the vlans allowed, etc but cannot see anything obvious?
Any ideas? Thanks
glen.grant Wed, 05/13/2009 - 07:28
  • Purple, 4500 points or more
If this is a transparent setup make sure the layer 2 vlan for vlan 31 is created on each switch . Verify on each switch with the show vlan command and make sure vlan 31 shows active.
darren-carr Wed, 05/13/2009 - 22:53
Guys
I shut down the portchannel between the two switches, re-enabled and the VLAN is now being forwarded over the switch.
Not sure why it stopped or if something caused a STP reconvergence or something...anyway.. all is good now... thanks for you input
Darren
