05-13-2009 12:11 AM
I've found many conversations about the known error occuring on some 3550 switches during an inventory collection ("device sensed, but inventory collection failed".)
A minimum IOS version must be installed. In my case, I upgraded the 3550s to 12.1(22)EA1.
But on 9 switches, 6 still failed.
I've checked the configuration, the passwords on each one.
Does someone successfully succeed in collecting this category of swtichs ?
thanks
Herve
05-13-2009 06:49 AM
null
05-13-2009 08:36 AM
For 3550 series switches, you need 12.1(19)EA1 or higher. This code should be okay. Post the IC_Server.log after trying to fetch the inventory for one of the affected switches. What version of RME are you using?
05-14-2009 12:28 AM
05-14-2009 08:40 AM
This looks to be exactly the same problem as with the older version of code. Try removing this device from RME, then re-add it. If the inventory collection problem persists, open a TAC service request with the IC_Server.log, and the show tech from this switch so more analysis can be done. you may have stumbled on a new bug.
