3550-12G Crashed
May 13th, 2009
I have a 3550-12G Switch. Last Saturday, after issued the "show cdp nei detail", the switch was hung and then crased.
From the "show version", I saw the following message.
System returned to ROM by error - Program Exception (0x0700)!, PC 0x0.
And the IOS Version is 12.1(22)EA1a, is this a bug? I can't find it in bug toolkit.
glen.grant Wed, 05/13/2009 - 03:24
  • Purple, 4500 points or more
Don't know if it is or not but code version is pretty old , believe it is up to like 12.2.44SE6 or something like that now . this what the output interpreter says which sort of points to software.
ERROR: A system crash due to the 'Program Exception' error is usually caused bya software issue.
Leo Laohoo Wed, 05/13/2009 - 13:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If you do a "dir", can you find the crashinfo file? If so, can you attach the file so we can have a look?
huang.jeff Wed, 05/13/2009 - 16:49
LT-3550-12G-2#more crashinfo_1
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(22)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 20-Aug-04 00:44 by yenanh
CPU Register Context:
Vector = 0x00000700 PC = 0x00000000 MSR = 0x0008B030 CR = 0x28000040
LR = 0x00004798 CTR = 0x0030F768 XER = 0x20000000
R0 = 0x00000000 R1 = 0x00FE2A70 R2 = 0x00000000 R3 = 0x8012F3D4
R4 = 0x012C2540 R5 = 0x00000000 R6 = 0x0000000F R7 = 0x00DC9AE8
R8 = 0x8012F27E R9 = 0x00AB0000 R10 = 0x0000F900 R11 = 0x00008600
R12 = 0x0000000E R13 = 0xFFB3FF7F R14 = 0x00003CB8 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x8012F294 R21 = 0x8012F3D4 R22 = 0x00000157 R23 = 0x00F28F7C
R24 = 0x00C10000 R25 = 0x8012F3B9 R26 = 0x00C0B274 R27 = 0x8012F298
R28 = 0x00000000 R29 = 0x00000005 R30 = 0x00000000 R31 = 0x012C2540
Stack trace:
PC = 0x00000000, SP = 0x00FE2A70
Frame 00: SP = 0x00FE2AB0 PC = 0x00004590
Frame 01: SP = 0x00FE2AF0 PC = 0x00003F8C
Frame 02: SP = 0x00FE2AF8 PC = 0x001E5D24
Frame 03: SP = 0x00000000 PC = 0x001E9350
LT-3550-12G-2#sh stacks
Minimum process stacks:
Free/Size Name
4864/6000 vegas_flash init
3928/6000 SaveCrashBuffer
5660/6000 vqpc_shim_create_addr_tbl
5640/6000 SPAN Subsystem
11544/12000 Router Init
9136/12000 Init
5372/6000 RADIUS INITCONFIG
4520/6000 Vegas CrashBuffer
8132/9000 DHCP Client
9412/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
4 8624657 8156/9000 CPU NETWORK INTERFACE CHIP
5 6302 8900/9000 Vegas miami tty xmit hack timer
6 65879356 8936/9000 Clock Timer Vector
Spurious interrupts: 13129
System was restarted by error - Program Exception (0x0700)!, PC 0x0
Compiled Fri 20-Aug-04 00:44 by yenanh (current version)
Image text-base: 0x00003000, data-base: 0x0083AF00
Stack trace from system failure:
FP: 0xFE2A70, RA: 0x0
FP: 0xFE2AB0, RA: 0x4590
FP: 0xFE2AF0, RA: 0x3F8C
FP: 0xFE2AF8, RA: 0x1E5D24
FP: 0x0, RA: 0x1E9350
******* Information of Last System Crash **********
Using flash:/crashinfo/crashinfo_1.
Stack trace:
Leo Laohoo Wed, 05/13/2009 - 19:59
  • Hall of Fame,
    2017 LAN, Wireless
Don't see anything helpful from the crashinfo.
Why don't you try to upgrade to 12.2(44)?
huang.jeff Thu, 05/14/2009 - 01:47
Due to production issue, I can't upgrade it right now. But I will suggest my customer upgrade it to the latest version if possible.
Thank you.
