Css 11500 Error
May 13th, 2009
Hi all,
I´ve search for this error but not found it anywhere.
This is ssh related.
Could u help me please ?
<em>
SSHD-0: Read from socket failed: errno = 0x36</em>
Best Regards,
Bruno Petronio
sachinga.hcl Wed, 05/13/2009 - 12:49
  • Silver, 250 points or more
Hi Bruno,
If your software supports an encrypted access protocol such as SSH, Cisco recommends that you enable only that protocol and disable Telnet access when you want to use the SSH server. In order to enable the SSH Daemon (SSHD), you need an SSHD server license, which enables SSHD functionality on both the Standard and Enhanced versions of CSS software. Issue the sshd commands.
SSH version 1 support started in 4.01. SSH version 2 support started in 5.20.
Can you send me the output of
# sh ver
# show sshd version
# show sshd config
All your questions are answered in the following documents :
"Configuring CSS Remote Access Methods"
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v7.20/configuration/administration/guide/Access.html#wp1105322
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v7.30/command/reference/CmdGlobC.html#wp1108716
If you see any problems I'd appreciate being pointed in the right direction.
Best Regards,
Sachin Garg
litrenta Tue, 05/19/2009 - 11:57
  • Cisco Employee,
This message is from SSH it means the CSS had a SSH connection established and was
expecting data on the connection. When the CSS went to read data from the underlying
socket the read returned an error and the message is logged and the SSH connection closed
down by the CSS. This is usually caused by an abnormal ssh session close where the client does not send a fin or rst when he closes down.
