LMS Portal 1.1 Applets won't stay where placed
May 13th, 2009
LMS 3.1, LMS Portal 1.1 on Windows 2003 R2. I arrange the applets in the Functional tab to suit my use. On a reboot of the server, the applets revert to either some sort of default position, or are placed randomly. Is there a way to make the layout permanent?
Joe Clarke Wed, 05/13/2009 - 08:20
No. The Functional View is built from dynamic data (i.e. based on the applications registered with Cisco Management Information). This data is stored in a format which promotes quick look ups rather than linear searches, and thus may be loaded in a different order each time the Portal initializes.
As a workaround, you can create your own View, add the portlets you want in the order you want, then set that View to be the default. The order should then not change.
