Increase the size of the CDR database
May 13th, 2009
Is there a way to increase the size of the CDR database. It appears to only hold about 60 days worth of data. Also, is there any way to retrieve something older than 60 days? I need to get some billing from Feb 2009.
Mike C.
Overall Rating: 4 (1 ratings)
Jaime Valencia Wed, 05/13/2009 - 05:47
  • Cisco Employee,
  • Hall of Fame,
    2011
I assume this is linux, the answer is NO. DB space is pre-allocated during install and is fixed, no means to modify it.
CUCM as you mentioned does not hold data for more days, if you need to keep records for longer periods you will need to configure a billing server to send the flat files and store them off-box.
java
if this helps, please rate
