WLC 526 - 5.2.157.0 local eap
lukas.sura
Community Member
hi all,
For customer solution, I tried use WLC 526 with 5.2.157.0 (in release notes, local eap mentioned as new funkcionality, but when I configured it by WLC release 5.0 configuration guide - it doesnt work.
from sh wlan <ID> command i always see that,
Local EAP Authentication......................... Disabled
and CLI command (config wlan local-auth enable profile_name wlan_id) cannot be used and on GUI for that WLAN, enabling local eap is missing...
I also tried fw: 5.2.178.0 with same result
Any advice ??? Maybe BUG (not find)???
LUKAS
aghaznavi
Level 5
Level 5
Ensure you have created the correct profile. Use this document to Configure Local EAP on the WLC.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a008093f1b9.shtml#wlc
