Automating output of "show" commands -- RME Netshow
May 13th, 2009
Hi All,
I need to generate a set of "show" commands daily for a group of devices, and have the text output for each device stored on a server share. For example switch 1 would have a file called switch1_show, switch 2 would have a file called switch2_show, etc.
I would like to use the Netshow tool provided by LMS 3.1, RME. My plan is to:
1. Generate NetShow jobs (with the cwcli interface) for each device. I would generate one job per device since it would be easier to separate the text output into different files for each device.
2. Use following command to create the text output
cwcli netshow jobresults -u xxx -p xxx -id xxxx -output c:\temp\switch1_show.txt
The "cwcli netshow jobresults" command above works fine in a manual process. It's manual because it requires the job id.
I need to automate this procedure, and my problem is trying to find the job id for step 2. Is there a way that cwcli can automatically obtain the job ID without any user intervention?
Does anyone have any suggestions?
--Max
Joe Clarke Wed, 05/13/2009 - 08:31
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You could use the listjobs command to get a list of jobs. For example:
cwcli netshow listjobs -u xxx -p xxx -status C
Listing all completed jobs.....
Job Id = 1358
Job Owner = admin
Scheduled at = Mar 13 2009 15:34:58
Completed at = Mar 13 2009 15:35:32
Sheduled type = Immediate
Job Run Status = Successful
Job description = Multi-command test
Job Id = 1419
Job Owner = admin
Scheduled at = Apr 08 2009 20:45:51
Completed at = Apr 08 2009 20:46:32
Job description = IPC test
Job Id = 1420
Job Owner = admin
Scheduled at = Apr 08 2009 20:47:13
Completed at = Apr 08 2009 20:48:01
Job Run Status = Failed
Job description = IPC Test 2
SUMMARY
Successful: listjobs
You could then parse that output in your wrapper script to find the job ID you want.
max12341234 Thu, 05/14/2009 - 04:06
Thanks jclarke,
Yes, I was aware of that command. As you mentioned, it would require that I write a script to search for the job description and assoicate it with the job id. This would take me a while to create since I'm not a scripting expert. It would be nice if Cisco updated the cwcli so that I can send the job output to a file. I'm surprised more users don't ask for this feature.
Joe Clarke Thu, 05/14/2009 - 09:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is the first I've heard of someone wanting to dump all of the Netshow jobs outputs to a file. There would be no other way to do it since there could be multiple jobs in Netshow (even multiple jobs for the same device). However, you could talk to your account team, and have them create a Product Enhancement Request on your behalf.
max12341234 Thu, 05/14/2009 - 09:50
Hi jclarke,
Since the jobs can be created with the cwcli command, it would be nice to have the -output option.
cwcli netshow createjob -u Username -p Password -commandset “Command Set 1” -output c:\temp\output1.txt
If you don't think it would help other, we don't need to do a product request. I'm now trying to find a way to output the set of show commads via a custom SSH script.
Thanks for your help!
Joe Clarke Thu, 05/14/2009 - 09:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Adding such a feature would be useful, but as far as I know, no one has requested it.
