AIR-AP1231G - false Vendor Type and Model Name
Answered Question
May 13th, 2009
we use a lot of accesspoints AIR-AP1231G-E-K9 and I want to generate an inventory report of theese devices.
OID: .1.3.6.1.4.1.9.1.525
But some of the devices are not shown valid (screenshot), others are right.
The IOS is the same on all devices.
The only difference is the Top Revision Number:
False devices: B0
Right devices: A0
Is there a issue with the device package? I installed the latest versions, but it doesn't work.
Thanks a lot!
Correct Answer by Joe Clarke about 7 years 9 months ago
The fix was to properly read correct values from the hardware based on the version, so it is entirely possible one board rev is fine while another is not.
It looks like the fix was also integrated into 12.3(8)JEC which you may be able to move to.
Overall Rating: 5 (1 ratings)
Sven Hruza Thu, 05/14/2009 - 00:12
Thanks for your reply!
Is it right, that we have the problem with the IOS c1200-k9w7-mx.123-8.JA2 in context with the special Top Revision Number "B0"?
Because other accesspoints work fine with the same IOS.
Because an update is not possible I have to live with this fault....
Sven Hruza Thu, 05/14/2009 - 01:47
For the completeness I attached the "show version" for a accesspoint with the right model name and one for the wrong model name.
The processor board revision number is different, too.
Correct Answer
Joe Clarke Thu, 05/14/2009 - 08:45
Sven Hruza Mon, 05/18/2009 - 07:51
I found a accesspoint to test the 12.3(8)JEC and it works!
Thanks for your response, Joe!
