LMS Backups are failing
Answered Question
I am running CW LMS 3.1 on Windows.
My backups are failing due to a validation error on DFNINVDB. I have attached the section of the d:\cscopx\backup\BackupInfo.txt file. Any assistance appreciated!
Rob
<strong>Attachment Keywords : </strong>
1) CiscoWorks_Backup_Error.txt
Correct Answer by Joe Clarke about 7 years 9 months ago
Jrm is unable to properly authorize itself. your current system identity user is admin. If you are integrated with ACS, and admin is not a user configured in ACS with full access to all of the LMS devices, applications, and tasks, you will need to define such a user in ACS, then go to Common Services > Server > Security > System Identity Setup, and define that user in LMS.
Once the System Identity User is corrected, restart Daemon Manager, and LMS should be working for you.
That's a command argument, not an error. Post the CTMJrmServer.log, the output of pdreg -l CTMJrmServer, the jrm.log, and the output of pdshow.
This log just confirms that CTMJrmServer is down. Where are you seeing the OutOfMemory errors?
You need to use the NMSROOT/bin/restorebackup.pl command. For example, to restore generation 10:
NMSROOT/bin/perl NMSROOT/bin/restorebackup.pl -d D:\backup -gen 10
Overall Rating: 0 (5 ratings)
Joe Clarke Wed, 05/13/2009 - 08:43
It appears your dfmInv database is corrupt. You will either need to restore from a known good backup, or reinitialize your DFM Inv database. to reinitialize the database, run:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
Correct Answer
Joe Clarke Wed, 05/13/2009 - 11:52
Correct Answer
Joe Clarke Thu, 05/14/2009 - 09:02
Correct Answer
Joe Clarke Thu, 05/14/2009 - 09:16
Output from pdreg:
D:\>pdreg -l CTMJrmServer
Process = CTMJrmServer
Path = D:\CSCOpx\bin\cwjava.exe
Flags = -cw D:\CSCOpx -cw:jre lib/jre -XX:+HeapDumpOnOutOfMemoryE
rror -cp:p MDC/tomcat/webapps/rme/WEB-INF/classes,MDC/tomcat/webapps/rme/WEB-INF
/lib/ctm.jar,MDC/tomcat/webapps/rme/WEB-INF/lib/log4j.jar com.cisco.nm.rmeng.jrm
wrapper.server.CTMJobManagerServer ATLAP05
Startup = Started automatically at boot.
Dependencies = jrm TomcatMonitor EssentialsDM
** NOTE **
Only the last pices of the jrm.log is attached due to the size of the log fine (160MB)
Rob
Correct Answer
Joe Clarke Thu, 05/14/2009 - 10:24
