Invalid call reference value
May 13th, 2009
I have a PRI terminated into Cisco 2821 Router. All the 30 chanels are allocated to us. The problem is from Voice gateway whenever we make outbould calls we get the error message " Cause i = 0x8AD1 - Invalid call reference value ". But we can find the calling party no in the router.
Plz find the debug for the outbound calls.
aredxbhobvgwan01#isdn test call interface serial 0/1/0:15 2337777
4294967296w4294967296d: ISDN Se0/1/0:15 Q931: Sending SETUP callref = 0x00AD callID = 0x802E switch
= primary-net5 interface = User
1w0d: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00AD
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Called Party Number i = 0x81, '2337777 '
Plan:ISDN, Type:Unknown
1w0d: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80AD
Exclusive, Channel 31mon
1w0d: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00AD
Cause i = 0x80E6 - Recovery on timer expiry
4294967296w4294967296d: ISDN Se0/1/0:15 **ERROR**:CCPCC_CallOrigination:SETUP timed-out (2nd T303) to NETWORK.The SETUP failed.
All parameters are in sync with ISP.
Plz suggest.
Paolo Bevilacqua Wed, 05/13/2009 - 10:06
  • Hall of Fame,
    Founding Member
Exact IOS? Can you send show controllers E1 ?
chrysostomos1980 Thu, 07/01/2010 - 07:32
  • Silver, 250 points or more
Hi to all
i didnt open a new document since we have the same problem here
Pls someone can help with this problem
i am experiencing the same problem(But this time the problem appeared only in incoming calls and not to outgoing)
ei controller 0/1/0
incoming:problem
outgoing:ok
