Warning message
Not able to make outgoing calls from Voice rtr
May 13th, 2009
We are setting up CUCM 7.0 & have integrated the same with voice gateway Cisco 2821 using MGCP.Now we are testing the communication link (PRI - E1) from the router by doing a test call.
<strong>Problem: We are not able to make test calls from our voice gateway router.
</strong>We are able to see ISDN link up with 'multiple-frame established'
I have attached the rtr bkp & debug output.Any ideas ?
Rgds./Sack
Kenneth Mohammed Wed, 05/13/2009 - 10:06
  • Silver, 250 points or more
Im not too sure what is causing the problem with outbound calls, however on the inbound call, you are getting the error "unallocated/unassigned number". This means that CUCM cannot find a pattern (phone, route pattern, translation pattern, CTI route point) etc with 777.
Check that ext 777 is in a partition that is reachable by the gateway's calling search space.
Hope that helped, if so please rate.
