How do i event log when a IPSEC L2L tunnel goes down?
May 13th, 2009
I am familiar with the web portion on a VPN concentrator 3000, however, i have some tunnels that I want to monitor. Just incase one of our tunnels goes down, i want it to be able to email me. ONLY if a IPSEC L2L tunnel goes down.
Help!
Select Monitoring > Statistics > IPsec to verify if the tunnel has come up in the VPN 3000 Concentrator. This contains the statistics for both IKE and IPsec parameters. You can actively monitor the session at Monitoring > Sessions. You can reset the IPsec tunnel here. The below URL describes how to configure the E-mail Alert feature on the VPN 3000 Series Concentrators. The E-mail Alert feature is available in both 2.x and 3.x releases. However, the 3.x release and later is preferred.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00800942a0.shtml
