ISDN Layer 2 issue ?
We have a CISCO 2811 gateway with 2 T1 port. The serial interface 0/0/0 is confiqure to connect a T1 PRI (NI2). The configuration is push by our call manager 6
The ISDN status is:
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI = 13, Ces = 255, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 145
The layer 2 status return this message
We can place and received calls from this T1. What is the meaning of this message?
We have other T1 comming in other CISCO 2811 gateway and we have no message like this.
chadlincoln Wed, 05/13/2009 - 11:52
  • Bronze, 100 points or more
Can you post the show run of the router? Thanks.
TAC solved the problem yesterday.
1- On the interface Serial0/0/0:23 write no in front of the fowlowing lines.
no encapsulation hdlc
no isdn switch-type primary-ni
no isdn incoming-voice voice
no isdn bind-l3 ccm-manager
and shutdown the interface
2- shutdown voice-port 0/0/0:23
3- shutdown controller T1 0/0/0
and add no pri-group timeslots 1-24 service mgcp from controller T1 0/0/0
4- wr (save the config)
5- reload the gateway
After that the gateway downloaded the config from the call manager.
No more error with the isdn status.
