Nokia client and iPhone on the uc520
Eivind Jonassen
Level 4
Level 4
I´m trying  to setup a demo of the nokia client on the UC520, having some difficulties though. The Nokia client can´t seem to connect/register towards the UC, also have difficulties connecting to the Voice WLAN. Anyone have a GOOD guide for the setup???
Also I would like to try and setup an iPhone on the UC, have downloaded a SIP client on my iphone, but don´t know where to go from there, any help is appreciated.
Eivind
2 Accepted Solutions
Douglas Smith
Eivind,
I'm not sure what materials you have used but The document found at
the following link
http://www.cisco.com/en/US/products/ps7320/products_white_paper09186a0
08096d82 a.shtml has information for Demo configuration of various
clients one specified is Nokia E60-1 Dual mode phone.
Also we have some information on E51 and E61 at
https://www.myciscocommunity.com/docs/DOC-1462.
Finally the Users guides, Quick Start Guide and Deployment guide from
Nokia may also be useful and can be found at
http://www.businesssoftware.nokia.com/nokia_intellisync_call_connect_f
or_cisco _downloads.php.
Hope this helps.
Douglas Smith
Can you try no encryption and open authentication first and see if you get it to work and register like that?
Marcos
6 Replies 6
Douglas Smith
Eivind,
the following link
Hope this helps.
Douglas Smith
Douglas,
I´ll take a look at the documents you posted.
Eivind
Douglas,
I´ve tried to follow the guides, and the nokia guide. I´m having some trouble with registering the nokia phone (cisco client) to the UC520. Not sure if there´s any limitations regarding security for the WLAN. I´m using WPA-PSK for authentication. Anyways, the UC is not picking up any registration messages.
Any idea on where to start troubleshooting?
Eivind
Marcos
Marcos,
Several mistakes in my config ;)
I had to add the phone before registering. Added the Nokia phone;
ephone 2
type 7960
button 1:x
Also, the voice wlan had an old configuration, the CCA wouldn't update correctly so I had to change some IP adresses for the VLAN in the WUI.
Eivind
I'm closing this post
Eivind
