doishi Thu, 05/14/2009 - 12:23
Since there is no native RTSP support in the iPhone, I haven't seen any applications that can view RTSP.  There are a couple of attempted ideas on how to make that work if you do a google search, but doesn't look promising.
Scott Olsen Thu, 07/16/2009 - 10:42
Actually, I've been able to successfully do this.  With both the Linksys and Cisco gear.  Mind you, it's on a jailbroken iPhone running a beta build of VLC media player.
I've been able to stream via WiFi, and both 3G and EDGE over IPSEC VPN ;-)
Cheers!
Eivind Jonassen Thu, 07/16/2009 - 23:19
Scott,
That's great. What about the app store? Can you post your app there?
Eivind
Scott Olsen Fri, 07/17/2009 - 06:15
Like I mentioned above,  it was on a Jailbroken iPhone running a beta build of VLC media player.  Last time I checked, I don't believe there were any Apple sanctioned apps capable of RTSP in the app store.  It would be wonderful if there were.  Obviously there's a demand.
Scott.
Steffen Bruening Thu, 05/06/2010 - 14:37
There is an App in the AppStore called "LinksysCams" which you can buy (3,99 Euro). With this App you can connect to the video stream of all available small business video surviallance cameras (also wvc210) over the local wireless network.
Steffen
Related Content
