05-13-2009 01:09 PM - last edited on 03-25-2019 10:36 PM by ciscomoderator
Our customer requested that we set thier system to use 8 as the outbound lead number rather than 9.
We configured that and it works fine.
But when users try to return a missed call or place a call from their received calls using their call log, they enter EditDial softkey with the lead 8, and the call does not go through. They get a fast busy.
They are using 524SG handsets.
What are we missing ? telephony-service shows the 8.T , dial peers look correct...are we missing something in CUE ?
Stacy
Solved! Go to Solution.
05-14-2009 02:04 PM
It works for SIP too. You just need to modify the rule according to the format that your provider is presenting to you (7 digits, 10 digits, leading "+" sign, etc.).
Marcos
05-13-2009 01:37 PM
05-13-2009 02:23 PM
Marcos- I want to be sure I am understanding corectly- the thread you sent removes having to use edit dial altogether correct ?
and in the voice-translation rules I can simply replace the 9 with an 8 for my specific case ?
05-14-2009 12:30 PM
Can you clarify for me please?
I am looking for a solution to fix the use of the lead 8 in the instance of returning calls from the call logs. EditDial + 8 + 'missed call' does not work.
If your solution to this is to remove the need to EditDial + 8 , I am all for that as well.... but I am not sure if that's what the doc/thread reference is earlier in this discussion.
Please clarify, I need a solution,
Stacy
05-14-2009 12:49 PM
The thread I pointed you to adds a 9 to the calling number for inbound calls, so when they are listed in the "missed" calls directory you can just select one and hit dial. Just replace the 9 with an 8 and properly identify the dial peers (POTS or VOIP) that will need to have this translation rule for the calling number.
I hope this helps,
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
05-14-2009 01:48 PM
Thanks so much- one last question- will this example config work for a SIP set up ? or are there slightly different steps involved ?
Stacy
05-14-2009 02:04 PM
Marcos
